Loose Cursor when trying to divide line
tytower
I have the following at present
Version: master
SCM Revision: 2.1.0
Compiler: GNU GCC 4.8.4
Qt Version: 4.8.2
Compiled on: Dec 18 2015
Portions (c) 2011 by R. van Twisk
Program Icons Supplied by
   Pablo: LibreCAD Argentine
Splash and Logo supplied by
   Diego Daltom Designer
Modules: Align, Read ascii points, Import ESRI Shapefile, List entities, Same properties, Sample plugin
As above trying to divide a line I lose the cursor altogether on my black background and it returns on all out side edges of the drawing . Changing background does not help.
Re: Loose Cursor when trying to divide line
Thanks; I fixed it.
You can disable "Hide cursor when snapping" until you update.
tytower
Thanks . I found
ravas wrote
Thanks; I fixed it.
 did not change it for me but if I can get the line I want to didvide zoomed up I can find it from the edge and turn it green ,select it, then I get the crosshairs and all is OK
