Lua Scripting Language
geopython1916
Hello, my name is Joseph O'Connor from Lake Worth, Florida. I'm currently working with Laing Survey, also in Lake Worth. We are working on embedding the Lua Scripting Language into LibreCad 2 and or LibreCad 3, which ever one could be completed first I'm attempting to use the SWIG Program to automate the task. I prefer working on the current stable release, using a release Candidate would be great also. That's our plan, and we're sticking to it. Joseph OC
Re: Lua Scripting Language
Welcome Joseph!
I recommend to join us at https://librecad.zulipchat.com/.
There you will find Florian, who is the one you need for LibreCAD 3 support.
By chance, do you already have some more detailed plans or mockups about your project?
Basically I advocate Ries' recommendation to go with LibreCAD 3, it is exactly intended for this kind of usage.
Where I have doubts is your target of Sept. '22. I'm not sure if LibreCAD 3 is in a state then where it can fulfill your requirements. On the other hand my plan for LibreCAD 2 is a final release soon and then focus on V3 too. So I'm not sure if it makes sense to put in efforts in interfacing with V2. Where I expect much more work with V2 implementation than V3.
