Margins when exporting to pdf
bikecycler
Greetings all, thanks for the forum!
I have been drawing in LibreCAD for four years or so. Today I upgraded to 2.2.0 (windows, 64 bit) in order to take advantage of the ability to select several layers.
A funny thing happened in that the margins - that is, the area that will not 'print' - seems to have grown. I previously had a titleblock with lines around the edge that would always print. Now that same titleblock edge goes missing all the way around. This happens regardless of what margins I enter. Strangely, the area cut off is larger on the right side.
I could adjust my titleblock, but I have a lot of drawings already produced in LibreCAD and would like to be able to keep going with those, without remaking their titleblocks. If you have a suggestion, I'd love to hear from you!
Happy drawing and thank you!
Re: Margins when exporting to pdf
bikecycler
Well, thanks for reading. I had a deadline to meet, so adjusted my border until it printed and went with it. If anyone knows how to adjust this non-printing edge, or where the setting might be - it only is happening since updating to 2.2.0 - I'd appreciate it. Otherwise I may just have to adjust all the existing drawings as I reprint them.
Thanks to the contributors and users. I appreciate the project and updates!
aman
Hello and welcome!
I usually print from printpreview, where you can do some modifications.
We also have the command line support for dxf2pdf
librecad dxf2pdf foo.dxf
aman wrote
Hello and welcome!
In reply to this post by bikecycler
In LibreCAD 2.2.0 multi-page printing has been introduced, and with this all the trouble with margins came along. It is hard to understand what is going on. A while ago I have examined the issue, but have forgotten what I have found out. It is complicated. My advice is to print in V 2.1.3 if this went well for you. You can use the portable version from portableapps.com in parallel to the normal installed version. But I don't know if 2.1.3 is still available there.
@ the developers: I advocate to remove the multi-page printing feature and return to the old system, or to iron out the issues of the new one. A detailed explanation might also help.
