Missing Array & Spacing when Inserting a Block in 2.2.0.2 appimage version
iembry
Greetings, my name is Irucka and I am using the LibreCAD appimage version for the first time.
Please see the version information below:
Version: 2.2.0.2
Compiler: GNU GCC 9.4.0
Compiled on: Jul 29 2023
Qt Version: 5.12.9
Boost Version: 1.75.0
System: Trisquel GNU/Linux Etiona (9.0.2)
I also have an older version that is installed system-wide. The user settings of the appimage version have been pulled from the older version.
Please see the version information below for the installed version:
Version: 2.1.2
Compiler: GNU GCC 7.5.0
Compiled on: Mar 13 2023
Qt Version: 5.9.5
Boost Version: 1.65.1
Anyways, I only have access to the Angle and Factor when attempting to Insert a Block. Please see the screenshot:
Insert Blocks screenshot
I am referencing the documetation here: https://docs.librecad.org/en/latest/guides/blocks.html?highlight=insert#inserting-blocks regarding the other items that should be there.
What should I do to have the Array & Spacing as well?
Thank you.
Irucka
Re: Missing Array & Spacing when Inserting a Block in 2.2.0.2 appimage version
Array and spacing you only get with the Blocks tool, when inserting a block that has been made a part of the drawing file, out of the Blocks list. The screenshot you show is about inserting something from the library and the Library Browser. This behaves differently.
iembry
Thank you for the clarification.
