Modify>Divide from the command line
licomol
Version 2.1.3
Debian 10
I would like to use Modify>Divide from the command line.
I type divide and get a prompt "specify entity to cut", is there a way to select an entity from the command line?
After selecting with the cursor comes "specify cutting point" which I have tried to introduce like I would when creating a line, but it doesn't seem to work as I keep getting the prompt "specify cutting point" over and over
Example:
->divide
->(I select entity by clicking entity)
-> 0,5
-> 0,5
Re: Modify>Divide from the command line
I have tested it, and indeed, neither selecting an entity nor specifying the cutting point works via command line. Darn!
