Modify a line
3 messages Options Options
Modify a line
Jimts
I am working thru the the user,s manual for 2.0.  (great document),  I am at the section fr drawinf isometric. Am instructed to deal with a partly hidden line. instructions are
1. Click on Modify...
2.On the pull down menu click properties.
3 Move your curser over the back edge of the part and click one time.  The line will turn red...
In does not turn red for me, there fore it does not appear selected and I am unable to modify the line.  Can someone please tell me how to proceed?  Thankyou
Jim
Re: Modify a line
Doesn't the checkbox pop up immediately after clicking on the line? If it does the line is selected and you can proceed and set the properties you want. It seems this function refers to always one object only so no highlighting is needed. In contrast, if you want to change attributes, you can select several objects and then close the selection with 'enter', in this case highlighting works. Maybe the instructions in the manual are just wrong or outdated.
Re: Modify a line
Jimts
Thanks very much for the helpful advice.
Jim
