Modify circle radius
4 messages Options Options
KENT-SET
Hello!
I am a total novice with CAD and design in general but am now exploring a little bit LibreCAD since I want to be able to design simple jigs/fixtures for benchtop robot systems.
Right now I am trying to design a small plate with different holes.
I have drawn the plate, and added a few circles already, but I would like to modify the radius of the circles (change 4mm to 5mm).
I have been searching for over an hour but cannot find the information.
Your help will be more than appreciated!
Re: Modify circle radius
Tools - Modify - Properties.
KENT-SET
Hello! Thank you for your reply.
I have tried but no menu appears. Is there something I am missing?
KENT-SET
I just found the solution!
I was doing the wrong method:
1) Select the circle
2) Click on tools, modify, properties
3) Nothing coming...
While the correct method was:
1) Dont select anything
3) Click on the circle
4) Modify the properties
