Just got back into my LibreCAD project.
With an rectangle and you add a arc to the top (like a rounded roof) how do you get the length dimension he arc. So there a 5 lines including arc in the drawing. All I can get is the straight line dimension not the arc with same end points .
In a rectangle etc I want to remove (erase) part only of 1 side. When I select I get all sides, only need 1 side.
When first used LibreCad has all default settings, how do you reset to these defaults.
Drag where are settings. Cannot get to work. Maybe because I am laptop. Should I still be able to drag. What laptop buttons. left, right, both plus ??
Thankyou
Charles Harris
