Move to new layer
Next Topic
13 messages Options
Move to new layer
Rick Ratzlaff
Is it possible to move an item from one layer to another?
Re: Move to new layer
Philip
Yes.  By default LibreCAD will create one layer named 0.  Create a second layer and name it.  For example, 1.  (Original uh?)  Then use Modify>Properties or Modify>Attributes.  Either one will allow you to change the layer of the item in question.
achilliesdev
In reply to this post by Rick Ratzlaff
What Phillip said works for single entities i.e. a single line or block.
If you want to change multiple items you have to activate Edit -> Application Preferences -> Default Tab check box  "Modify layer of selected entities, at layer activation.
WARNING: remember to turn this off after use otherwise any selected entity will change layers all the time
If you have the 0 layer selected and then check the box the entity selected will not change to that layer until you click on the 0 layer. So if you want the entity selected to be on that layer and it is select when you turn on the feature just select that layer agai after turning on the feature.
After you have completed all your entity layer changes go back into that setting and unselected the check box.
I hope this helps speed up your layer changing needs.
Note: if you want to just change a few entities such as a block or a few lines not massive amounts of entities then Phillip's explanation is the safest way. If you forget to turn the feature off you could actual create a massive time issue figuring out what entity was on what layer before all the changes. I learned this the hard way, spent days reorganizing a building plan back to the correct layers because I forgot to uncheck the box after moving a detail section over to a new layer.
With Modify - Attributes you can select multiple entities.
jefken
Hi
Both methods work perfectly:
For the second methode there is a little complication:
thanks for these wonderful tips
Jefken
P.S.
Is there a user manual with a bundle of practical drawing tips for the windows version 2.2.0.rc1? It will be great!
Now we have to search the forum for a solution.
Jefken
gepensioneerd ingenieur
Gent Belgiƫ
LibreCad 2.2.0 rc1 Windows
Gromit
I had trouble making this work until I selected the layer the entities current layer, then select the entities followed by selecting the destination layer.
This works nicely.  For the longest time I was moving entities one by one.  Yikes!
sand1024
another way to move or duplicate selected entitieis to another layer - it's just a command within Layers Tree widget (available from 2.2.1, I suppose).
Just select entities, right click on the layer to which you need move entities to  - and invoke appropriate command.
That's it...
Gromit
That's even easier!  I would love to add these things to the manual.  I searched the manual and the WIKI and did not find that.  I have noticed quite a bit of missing information that could be in the manual and I would be willing to add those since I really cannot (should not) help with the software development.
I have to look into that.
sand1024
well, yes, that's feature (as well as lot's of other ones, especially in 2.2.2 branch) are not included into documentation.
zamtmn
Sorry, I just couldn't help myself)) Developers, why are you doing such a bad thing? look at how it's done in AutoCAD and such simple questions will stop being raised on the forum
How is it done in AutoCAD?
zamtmn
You need to know the program that q\libre cad is trying to emulate))
There are comboboxes on the toolbar that display the parameters of the selected primitives (layer, weight, linetype, color, text style, dim style, ...) (in the case when there is no selection, they display the current values). You can also quickly change the parameters of selected primitives in these combos.  Moreover, this works for both single select and multiple selection
Gromit
Three years ago I was an AutoCAD LT user, but then I retired and I could not afford any AutoDesk software, especially since all of their software is subscription based!
Most things can be done with a right-click or in the properties of the entity.  One thing I really miss is the ability to select multiple entities then make a change to all of them at one time, like line type.  If there is a way to do that in LibreCAD I would like to know how.
I like LibreCAD and I have been able to learn (and remember ) the differences, but there are still some things I have not been able to figure out yet.
Still, the developers have done a great job.
Mike
