New LibreCAD CI features including static analysis
maqifrnswa
I set up LibreCAD to work with travis. All pull requests will be test built (you'll see it on the pull request).
Also, every commit will have clang's static analyzer run over it. The output will be visible:
http://librecad.github.io/static-analyzer-reports
There are already quote a few potential bugs. We can also set up a coverity scan, but that requires manual intervention. This static analysis is automatic.
I also built the packages on travis with clang, which has different warnings than gcc - and there were actually too many warnings that the build had to stop. That might be something to look at if you're interested in cleaning up some code -- try building librecad with clang and see what happens.
Re: New LibreCAD CI features including static analysis
maqifrnswa
> will be visible:
I just wanted to point out how cool clang's static analyzer is.
Here is a potential memory leak - it walks you through the source code
and tells you exactly which branches/conditions would cause the memory
leak and exactly where memory is allocated and not destroyed!
http://librecad.github.io/static-analyzer-reports/report-70f308.html#Path1
Thanks! That's very helpful.
I have been using clang for a few weeks now, but was unaware that it had a static analyzer.
It's much faster than gcc... a full build only takes 2.5 to 3 minutes.
The extreme amount of warnings (around 50k) can be suppressed with -Wno-inconsistent-missing-override
I did some research two nights ago, and ended up with this in my custom.pri
QMAKE_CXXFLAGS_WARN_ON = -Wall -Wextra -Wpedantic -Wno-inconsistent-missing-override -Wno-nested-anon-types
-Wno-nested-anon-types is needed because of muparser.
-Wdocumentation can be added for anyone interested in cleaning up the dox.
Ravas,
when you make builds for OSX (the DMG file for sourceforce)
it's best to use clang and a installation of Qt from www.qt.io.
Do not use macports for this!
The script build-dmg-externalqt-clang.sh (that uses build-osx.sh) attempt to make a few builds for the different versions of OS/X.
I did see if that the builds files have been modified, so make sure it will do the right thing.
This also means you don't need our mkspec for OS/X anymore, ensure that it's not used by any of the builds.
By default it builds with -j4 and I think I did read somewhere that for some users it fails, it always worked for me
but feel free to take that a notch back to -j 3.
Cheers,
Ries
The extreme amount of warnings (around 50k) can be surpressed with -Wno-inconsistent-missing-override
http://forum.librecad.org/New-LibreCAD-CI-features-including-static-analysis-tp5713349p5713351.html
I'm using Qt 5.5.1 which uses clang by default on OS X.
I don't use macports.
I don't use build-dmg-externalqt-clang.sh
You are remembering my email about -j4 and -j3.
It doesn't fail on -j4,
but things can freeze if I try to do anything else during the build.
-j3 already builds it in under 3 minutes.
