Object not deleted in main/qc_applicationwindow.cpp
8 messages Options
ClaudeQC
- In main/qc_applicationwindow.cpp, in the following function:
        slotFileExport( const QString& name, const QString& format,
                        QSize size, bool black, bool bw)
  The "painter" object is not deleted at the end of the export process.
- Code look like below:
    // GraphicView deletes painter
    painter->end();
    delete buffer;
- Should it be like:
    painter->end();
    delete painter;
    delete buffer;
Claude
Re: Object not deleted in main/qc_applicationwindow.cpp
In reply to this post by ClaudeQC
ClaudeQC
On 24/07/2011 09:15, R. van Twisk [via LibreCAD] wrote:
 > Claude,
 > what if we just do it like this??
 > This way we don't have to worry about deleting the painter at all.
Hello Ries,
- I don't like creating objects in the stack.
   Prefer to create them in the heap memory (with new).
- I don't know RS_PainterQt class.
   If this class is not too big in term of data memory usage, it may be
   acceptable to create associated objects in the stack.
Claude
ClaudeQC
On 24/07/2011 13:54, R. van Twisk [via LibreCAD] wrote:
 > I just asked this question on the IRC channel and they mentioned 'stack' :)
 > For this case, I think I need to agree with that. The QPainter is just used in
 > that function and doesn't use any memory anyways.
- Ok.
- Given your explanation, I agreed with you to create these objects
   from the stack.
Claude
