Offset feature LibreCAD
10 messages Options
tonny
Is there feature in LibreCAD to make offset like this? Or should I make a feature request?
[img]http://www.upl.co/uploads/librecadoffset.png[/img]
With current offset feature i must lenghten and trim entities after offset.
What I need is feature I select multiple entities, apply offset for them and offset like on screen is created.
I hope that my screen shows good functionality I need.
FreeCAD seems to have this feature. http://sourceforge.net/apps/mediawiki/free-cad/index.php?title=Draft_Offset I haven't tested it hovewer it seems to be ok. I will test and report here whether it works or not.
I've just noticed that for polyline this feature work as I want. But I want to do it for shapes not treated as polyline also.
Re: Offset feature LibreCAD
To create offset simmilar of attached image use
Draw->Polyline->Create Equidistant Polyline
But if entities are lines, first use
Draw->Polyline->Create Polyline from Existing Segments
to convert lines to polylines
tonny
[img]http://www.upl.co/uploads/libreoffset2.png[/img]
[img]http://www.upl.co/uploads/libreoffset3.png[/img]
I've just checked it and it seems it's still plenty of work on this functionality?
There is also some bug in trim functionality
[img]http://www.upl.co/uploads/libretrimm.png[/img]
It does not work in this case on screen. Red entities should be trimmed. I've tried to lenghten line but no result line is trimmed, arc is trimmed but the result is circle.
I made some test with current master brach (same code as alpha4), and this is the result:
As you can see it's not perfect, but there are improvements over the images you have attached
I added a patch in master branch code, and the result is:
All are polylines. Red are original drawn from left to right
Yellow are original drawn from right to left.
And white resulting polylines from offset
tonny
[img]http://www.upl.co/uploads/libreoffset.png[/img]
Still some problems with closed polylines.
To draw polyline:
start point> 0,0
next point> 10,0
next point> 10,10
next point> 0,10
next point> close (or click in "close" button)
With this command sequence are created a CLOSED "squared" polyliline
and:
start point> 0,0
next point> 10,0
next point> 10,10
next point> 0,10
next point>  0,0
With this command sequence are created a OPEN "squared" polyliline
The result with both methods is the same visually, but the first creates a closed polyline and the second an open polyline with the coordinates of the first point equal to the last point.
In this image left polyline are closed, and right are open, with "Edit->Modify Properties" you can check if polyline are open or closed (and change the status)
tonny
Thanks for patience. It works good for me. However found another bug I think.
This red polyline is closed and ends with arc. The result is wrong. When the same red entity is not closed the result is ok.
[img]http://www.upl.co/uploads/libreoffset4.png[/img]
http://pastebin.com/5Xqzvxfi
I think that I've figured it out. When polyline is closed bulge should not be set I think. See the comment in code above. I haven't tested it much, but solved all my test cases.
Another patch added, please test it.
If patch do not work or you found another bug open a bug report in:
so will be more organized and easier to find in the future
krzych
I've found another issue with offset feature.
[img]http://www.upl.co/uploads/issue.jpg[/img]
Here when using polyline equidistant and the length of polyline segment is too small offset is not generated correctly.
I'm using LibreCAD 2.0 beta1
martinst
In order to create bug reports it is only necessary to register in sourceforge:
https://sourceforge.net/user/registration
