Offsetting a curve with librecad
snowforest
I tried to offset a curve but the command seems to work only with straight lines. So I first exploded the curve (it was a spline), and then I selected the segment of it, and then when I said offset , it worked for a certain distance which I couldn't specify how much, but I repeated the command several times to get many offset lines and then deleted the intermediate ones.
I guess the offsetting of curves should be added to the program in its next release, if possible.
Re: Offsetting a curve with librecad
Set the distance for offset in the Tool Options bar above the drawing area. It changes the content according to the used command.
