Open dwg file
Open dwg file
Paulo Abreu
 I installed LibreCAD but my dwg files do not open and the following message appears:
            "DWG support is not complete.
             If this file fails to open try an older DWG format or try to find a converter to make it a DXF file".
I converted a file DWG in DXF and the file open but the screen continue empty.
Re: Open dwg file
Make sure the dxf version is 2007 Also, quite common, try auto zooming to fit the page to window viewport. https://wiki.librecad.org/index.php/A_short_manual_for_use_from_the_command_line#:~:text=You%20type%20za%20(abbreviation%20of,entire%20drawing%20%2D%20all%20the%20entities.
Paulo Abreu wrote
I installed LibreCAD but my dwg files do not open and the following message appears: "DWG support is not complete. If this file fails to open try an older DWG format or try to find a converter to make it a DXF file". I converted a file DWG in DXF and the file open but the screen continue empty.
