Opening DXF files into LibreCad but screen is blank
3 messages Options Options
flintstones
I have been trying to open a DXF file but when I open it, it shows a blank (empty) screen.  The Layer list displays the layers and the Command line says it loaded the document but there is nothing visible.  Importing the document has the same results.
I have googled this problem and other users suggest to do an Auto Zoom, Minimise/Maximise windows and Redraw after opening but this as no effect.
I have installed LibreCAD on 3 other PCs (2 x Win10 and a Win7) and all of them have the exact same problem.
LibreCAD details:
Version: 2.1.3
Compiler: GNU GCC 4.9.1
Compiled on: Sep 23 2016
Qt Version: 5.4.1
Boost Version: 1.60.0
I have attached the file and I would be very grateful if someone could help me out.
1553B.dxf
Re: Opening DXF files into LibreCad but screen is blank
aman
From the wiki FAQ.':The DXF import process failed, why?
LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007.'
Lilnk to that and other manuals are at the top of the main page.
flintstones
Thanks for the quick reply.  I have converted the file using https://cloudconvert.com/dwg-to-dxf and made both an R12 and a 2000 version.  Neither of the them worked and I have the same result (blank project).
I have also used DWG DXF Converter app from the Microsoft store and that has the same outcome.
Here is the file converted to DXF 2000 format. 1553B_2000.dxf
Thoughts?  Can anyone recommend a conversion system?
