Downloaded and installed SCM Revision: 2.0.8.
It can re-order the hatch fill after it is added. Still cannot re-order the rectangle lines.
In test drawing, added four boxes each on their own layer.
Started with lowest layer in list and moved up list one layer at a time.
Drew the box, then added hatch fill.
Hatch fill always goes on the bottom most spot.
Box lines always go on the topmost spot.
Fill can be moved up or down.
Box lines cannot.
What is the point of adding fill to the bottom if the box is on top?
Why is their no correlation between the layer order and the object order?
