Parallel line to a polyline or a closed contour
Hans-Werner
Re: Parallel line to a polyline or a closed contour
sp1der
I think this will be improved for version 2.0 but you could as a
'workaround' for now:
1.Create e.g polygon.
2.From polyline tools > create polyline from segments > select and 'double'
click on a line to produce a closed polyline!
3.Then use the polyline equidistant tool.
As I say this will I`m sure be improved.
On Mar 3 2012, Hans-Werner [via LibreCAD] wrote:
>I've done some parallel lines, one line parallel to another line.
>Can I also do a line parallel to a polyline or a closed contour ?
>For example:
>I wanted to draw a christmas star with five edges.
>First I draw (drew ?) a polygon, from that a pentagram.
>Then I used snap to drew the star an another layer using the pentagram.
>This seemed to be easier then to use divide and then to erase the redundant
>lines of the pentagram.
>(I don`t know how to use divide)
>Then I wanted a smaller star inside the first one 10 mm from the borders of
>the first one.
>How to do this ?
>I helped myself using parallels and extended and trimmed the lines.
>Is there an easier way to do this ?
> _______________________________________________ If you reply to this
> email, your message will be added to the discussion below:
> http://forum.librecad.org/Parallel-line-to-a-polyline-or-a-closed-contour-tp5534128p5534128.html
> To start a new topic under LibreCAD, email
> [hidden email] To unsubscribe from LibreCAD,
> visit
Clive
sp1der
Actually Hans
Thinking about it what might be easier is just using the modify > scale tool. Just use the center of your shape as the reference point and in the 'scale' options window - keep original and scale down/up to your required size.
*Note: you will need to select everything in order to use the scale tool and after selecting everything and activating the scale tool -just hit enter when you get the 'No entity selected' prompt.You will then get prompted for your reference point.
