Will to be right to package Part Library from: ftp://ribbonsoft.com/archives/partlibrary/partlibrary-2.1.2.8-1.tar.gz in LibreCAD?
Getting some good symbols, templates give user a kick start. -- H.S.Rai
H.S.Rai |
It's a good resource, but it isn't licensed for redistribution. Andrew Mustun holds the copyright, but it seems to have no license. If you can find out if we would be allowed to redistribute it, then we can package it in LibreCAD. Most likely it will be proprietary, which is fine but we can't include it. ~Scott On Sun, Mar 31, 2013 at 10:28 PM, hsrai [via LibreCAD] <[hidden email]> wrote: > Will to be right to package Part Library from: > ftp://ribbonsoft.com/archives/partlibrary/partlibrary-2.1.2.8-1.tar.gz in > LibreCAD? > > Getting some good symbols, templates give user a kick start. > > -- > H.S.Rai > > ________________________________ > If you reply to this email, your message will be added to the discussion > below: > http://forum.librecad.org/Part-Library-tp5707820.html > To start a new topic under LibreCAD-dev, email > [hidden email] > To unsubscribe from LibreCAD-dev, click here. > NAML |
This file is available in Ubuntu repository at: http://packages.ubuntu.com/hardy/all/partlibrary/filelist Which imply that we may include it. When LC was forked from QCAD, It should have been forked at that time. We have option: 1) Take from Ubuntu repository, if that imply that it can be redistributed. 2) Taking consent of Andrew Mustun. What could be more appropriate? And if it is not possible, we should start developing Part-Library, user contributed to it. -- H.S.Rai
H.S.Rai |
hi hsrai, this was discussed long time ago. We can not redistribute anything from qcad beyond what is already in LibreCAD now.
Dongxu On Mon, Apr 1, 2013 at 1:00 AM, hsrai [via LibreCAD] <[hidden email]> wrote: This file is available in Ubuntu repository at: Dongxu Li, Ph.D. www.librecad.org |
In reply to this post by hsrai
Thanks, Ubuntu is wrong, I'll request its removal.
A user-contributed part-library would be brilliant! If anyone wants to get one started please post to this list and we can coordinate here (probably a github repo so we can pull and merge from it) Regards, Scott On Mon, Apr 1, 2013 at 1:00 AM, hsrai [via LibreCAD] <[hidden email]> wrote: > showard314 wrote > It's a good resource, but it isn't licensed for redistribution. Andrew > Mustun holds the copyright, but it seems to have no license. If you > can find out if we would be allowed to redistribute it > > This file is available in Ubuntu repository at: > > http://packages.ubuntu.com/hardy/all/partlibrary/filelist > > Which imply that we may include it. When LC was forked from QCAD, It should > have been forked at that time. > > We have option: > > 1) Take from Ubuntu repository, if that imply that it can be redistributed. > > 2) Taking consent of Andrew Mustun. > > What could be more appropriate? > > And if it is not possible, we should start developing Part-Library, user > contributed to it. > > -- > H.S.Rai > > > ________________________________ > If you reply to this email, your message will be added to the discussion > below: > http://forum.librecad.org/Part-Library-tp5707820p5707822.html > To start a new topic under LibreCAD-dev, email > [hidden email] > To unsubscribe from LibreCAD-dev, click here. > NAML |
On Mon, Apr 1, 2013 at 9:18 AM, Scott Howard <[hidden email]> wrote:
> Thanks, Ubuntu is wrong, I'll request its removal. Quick update, partlibrary was removed from Ubuntu prior to precise release and is has not been distributed by ubuntu in the past two years of releases. |
In reply to this post by maqifrnswa
