Part Library
8 messages Options
Part Library
hsrai
Will to be right to package Part Library  from: ftp://ribbonsoft.com/archives/partlibrary/partlibrary-2.1.2.8-1.tar.gz in LibreCAD?
Getting some good symbols, templates give user a kick start.
H.S.Rai
H.S.Rai
Re: Part Library
maqifrnswa
It's a good resource, but it isn't licensed for redistribution. Andrew
Mustun holds the copyright, but it seems to have no license. If you
can find out if we would be allowed to redistribute it, then we can
package it in LibreCAD. Most likely it will be proprietary, which is
fine but we can't include it.
~Scott
On Sun, Mar 31, 2013 at 10:28 PM, hsrai [via LibreCAD]
> LibreCAD?
> H.S.Rai
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://forum.librecad.org/Part-Library-tp5707820.html
> To start a new topic under LibreCAD-dev, email
> [hidden email]
> To unsubscribe from LibreCAD-dev, click here.
> NAML
Re: Part Library
hsrai
This file is available in Ubuntu repository at:
http://packages.ubuntu.com/hardy/all/partlibrary/filelist
Which imply that we may include it. When LC was forked from QCAD, It should have been forked at that time.
We have option:
1) Take from Ubuntu repository, if that imply that it can be redistributed.
2) Taking consent of Andrew Mustun.
What could be more appropriate?
And if it is not possible, we should start developing Part-Library, user contributed to it.
H.S.Rai
H.S.Rai
Re: Part Library
hi hsrai,
this was discussed long time ago. We can not redistribute anything from qcad beyond what is already in LibreCAD now.
Dongxu
We have option:
H.S.Rai
http://forum.librecad.org/Part-Library-tp5707820p5707822.html
Dongxu Li, Ph.D.
www.librecad.org
Re: Part Library
maqifrnswa
In reply to this post by hsrai
Thanks, Ubuntu is wrong, I'll request its removal.
A user-contributed part-library would be brilliant! If anyone wants to
get one started please post to this list and we can coordinate here
(probably a github repo so we can pull and merge from it)
Regards,
Scott
> We have option:
> contributed to it.
> H.S.Rai
> below:
> [hidden email]
> NAML
Re: Part Library
maqifrnswa
Quick update, partlibrary was removed from Ubuntu prior to precise
release and is has not been distributed by ubuntu in the past two
years of releases.
Re: Part Library
In reply to this post by maqifrnswa
Re: Part Library
