Pen-size vs Pen-size for printing
3 messages Options Options
cenaluc
Hi all,
I am new with Librecad
I am trying to set the pen size for the printer (pdf) but I see that setting the width in the layer setting is not only changing the pdf: also the width in the cad view is changed.
Can I keep the 0mm setting at the CAD level and assign the non-zero width only for the printing and print preview?
Fantastic software anyway!
Thanks
Re: Pen-size vs Pen-size for printing
Welcome @cenaluc!
Your right, there is only one line width setting, used for screen and export (print, PDF).
But probably Draft Mode can help you. This was made to speed up rendering; images, text and hatches are disabled in Draft Mode, but also line width. It is easy toggled with CTRL-D or tool bar icon.
See https://docs.librecad.org/en/2.2.0_a/ref/menu.html#view
cenaluc
Hi LordOfBikes,
thanks for quick answer, much appreciated
