I'm struggling to find an answer to this in the manual or in previous posts, so any help would be welcome.
Quite often when I move a section of a drawing, which might be made up of many entities, and then try to UNDO, Librecad winds backwards one entity at a time, and doesn't put the entire selection back where it started. Not a problem perhaps if the selection is a handful of entities, but a major problem if its hundreds of entities.
Is this normal, is it a bug, is there a trick I'm missing? My default response to this is to close the drawing and start over, not ideal if you haven't backed up for a while.
Many thanks,
Jeff
