Problems with Librecad in new 18.1 Serena
11 messages Options
Cy O'Hara
I am getting back in after a heavy workload on the farm. Three problems, 1) problem getting the default Librecad from 18.1 Serena, it does not look anything like the application illustrated in the Software Manager?
2)/"Te package 'librecad' could not be moved (system error installArchives failed)?
3) Downloading from home of Librecad, does not seem to provide default settings?
Regards,
Cy
Re: Problems with Librecad in new 18.1 Serena
What is "the default Librecad"?
What is "home of Librecad"?
Default settings are part of the code,
and can not be excluded.
Cy O'Hara
Hi, Thank you for your speedy response, it is much appreciated.
The default that I talk about is the one that I see in the youtube tutorials with a drawing selection of two columns on the left of the modelling window. The author is  "TheReinber" (odd name) and the version of the cad prog is the same as the one shown in the 18.1 Serena loading window.
The home of Librecad is just the web site download page location.
In respect of the default settings not being available for altering the code, it is quite a mystery as I did not see this default setup in OS version 18 either with its standard download Librecad?
Kind regards,
Cy
That is the old CAD toolbar,
which I replaced with:
- dock widgets in the left dock area (hidden by default)
- a toolbar for each category
- the categories toolbar
- custom toolbars
- custom menus
http://wiki.librecad.org/index.php/User_Interface
Cy O'Hara
Thank you, well it all sounds very exciting, but I will have to sit down and work my way through all the changes and see how to load and use them.
Many thanks for your help,
Kind regards,
Cy
Cy O'Hara
Hello again,
I am considering reinstalling Mint version 18 because of some of the problems I have experienced, if I do this, will the Librecad from version 18 give me the changes you have mentioned?
Regards,
Cy
Please describe exactly how you are downloading LibreCAD.
Please copy the information from Help->About in LibreCAD.
Cy O'Hara
The two ways that I use are via the Librecad web site and the terminal window and of course I install with the Software Manager.
You need to provide more detailed information if you want help.
"via the Librecad web site"
What's the link?
I'm not aware of any linux downloads at librecad.org.
"terminal window and of course I install with the Software Manager."
Using what command, and what is the package name?
What version do you have installed now?
Which way did you download it?
What is the problem you have,
aside from the misconception about default settings?
Cy O'Hara
Thank you Mr Rivas for your help. I realise by the way things are going, that You have done as much as you can for me.
So, before saying goodbye. the Web detail you do not know about is Librecad.org
Kind regards,
Cy
