Problems with viewing - displayng the quotes, opening tranlated files DXF from DWG
2 messages Options Options
GiulioT
1 post
Hello. I'm new to librecad, and opening my DXF files translated from my DWG works, I have the problem that I can't see the quotes dimensions in a stable way, but i see only the rectangles that delimit the measurements, and i don't know the normal way to come to display quotes to view it, preferably in opening file.
Thank You,
(I'm italian and will you excuse me for my poor inglish).
Re: Problems with viewing - displayng the quotes, opening tranlated files DXF from DWG
aman
Welcome!
https://dokuwiki.librecad.org/doku.php/usage:faq#why_does_the_dwg_import_fail
Good to skim at least the FAQ after installing LibreCAD, links to howto's and other docs are at the top of the main page.
Check also, you are not in the draft mode, that has caused quite a lot confusion also.
Your English was decent enough, there are also free translators, use your search engine to find them.
