Properties of a Curve - End Co-ordinates
electrosteam
I use LibreCad to provide dxf drawings to a CAM package, to be used on a CNC mill.
The ordinary Properties command applied to a curve provides the co-ordinates of the centre and the angular values for the ends of the curve.
Is there a way to get the x,y co-ordinates of the curve ends ?
This would be very useful when trouble-shooting errant GCodes on the mill.
Keep well,
John.
Re: Properties of a Curve - End Co-ordinates
I just tried the Info plugin, but sadly, it doesn't show start/end coordinates too.
So I'm afraid, there is no direct way yet.
What you can do is to draw a simple 2-Points line with snap on endpoints from the curves start to end.
Then use Properties tool or Info plugin with the 2-Points line.
When you have more curves, place all the lines on a new layer which you can easy delete after checks or make it invisible.
electrosteam
Thanks, I thought it was me just not being diligent enough to find the requisite tool.
I will try a supplementary line (straight on new layer) exactly as suggested, thank you.
John.
