RPM for RHEL 6.x?
RPM for RHEL 6.x?
Todd
Hi All,
    Does anyone know of 2.0.4+ RPM for RHEL 6.5 (Red Hat Enterprise Linux)?
Many thanks,
-T
Re: RPM for RHEL 6.x?
Hi Todd,
At the momment I can't build Librecad for RHEL 6.5 because libstdc++ is too old and fails to build in librecad/src/lib/engine/rs_layerlist.cpp
lib/engine/rs_layerlist.cpp: In member function 'void RS_LayerList::sort()':
lib/engine/rs_layerlist.cpp:116: error: expected primary-expression before '[' token
lib/engine/rs_layerlist.cpp:116: error: expected primary-expression before ']' token
lib/engine/rs_layerlist.cpp:116: error: expected primary-expression before 'const'
lib/engine/rs_layerlist.cpp:116: error: expected unqualified-id before 'bool
make[2]: *** [../../generated/librecad/obj/rs_layerlist.o] Error 1
But, if you have installed a more modern version ( not libstdc++-devel-4.4.7-4.el6.x86_64.rpm or libstdc++-devel-4.4.7-4.el6.i686.rpm ) you can compile it
Required packages are:
32 bits
https://build.opensuse.org/package/binary/home:Rallaz/libdxfrw?arch=i586&filename=libdxfrw-devel-0.5.12-1.1.i686.rpm&repository=RedHat_RHEL-6
https://build.opensuse.org/package/binary/home:Rallaz/libdxfrw?arch=i586&filename=libdxfrw0-0.5.12-1.1.i686.rpm&repository=RedHat_RHEL-6
64 bits
https://build.opensuse.org/package/binary/home:Rallaz/libdxfrw?arch=x86_64&filename=libdxfrw-devel-0.5.12-1.1.x86_64.rpm&repository=RedHat_RHEL-6
https://build.opensuse.org/package/binary/home:Rallaz/libdxfrw?arch=x86_64&filename=libdxfrw0-0.5.12-1.1.x86_64.rpm&repository=RedHat_RHEL-6
And LibreCAD sources:
https://build.opensuse.org/package/binary/home:Rallaz/LibreCAD2?arch=x86_64&filename=librecad-2.0.4-1.1.src.rpm&repository=openSUSE_Factory
To build:
1. install Qt-devel and all dependencies, muparser-devel (if not are present in REHL6 you can download from http://download.opensuse.org/repositories/home:/Rallaz/RedHat_RHEL-6/) and libdxfrw-devel
2. Put a copy of librecad*.src.rpm in /usr/src/packages/SRPMS/ cd to it and
3. exec rpmbuild --rebuild (in console)
Todd
On 06/30/2014 12:01 PM, Rallaz [via LibreCAD] wrote:
> Hi Todd,
> before '[' token
> before ']' token
> before 'const'
> before 'const'
> 'bool
> 32 bits
> 64 bits
> To build:
> and libdxfrw-devel
Hi Rallaz,
Wow.  Thank you.  It is pretty far over my head unfortunately.
Can you do a devtoolset-1.1 which has g++ and which accepts -std=c++11?
http://ftp.scientificlinux.org/linux/scientific/6rolling/x86_64/external_products/devtoolset/
To fire it up, you have to do a
    scl enable devtoolset-2 'bash'
In your command window.
I got this far and had to give up:
# rpmbuild --rebuild librecad-2.0.4-1.fc19.src.rpm
lib/filters/rs_filterdxfrw.cpp: In member function 'virtual void
RS_FilterDXFRW::writeHeader(DRW_Header&)':
lib/filters/rs_filterdxfrw.cpp:1479:22: error: 'class DRW_Header' has no
member named 'addInt'
                   data.addInt(it.key().toStdString(),
it.value().getInt(), it.value().getCode());
Others told me I need a newer libdxfrw
Many thanks,
-T
Todd
Hi Rallaz,
Many thanks,
-T
Hi Todd,
I do not have any REHL6, I use https://build.opensuse.org to build RPMs for OpenSuse, Mandriva and Fedora.
Yes, you need to install libdxfrw 0.5.12 but, if you use a src.rpm form fedora packagers and a modern devtoolset,  the best is to rebuid libdxfrw, download it from here:
https://build.opensuse.org/package/binary/home:Rallaz/libdxfrw?arch=i586&filename=libdxfrw0-0.5.12-1.1.src.rpm&repository=RedHat_RHEL-6
Cheers,
