Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On Thu, Apr 19, 2012 at 3:19 PM, Scott Howard <[hidden email]> wrote:
> It's in the daily builds... someone should fix that {looks in the mirror}... > > I'll take a look at it Ok, so it looks like librecad builds everything it needs in unix/resources which has: doc fonts library patterns plugins qm However, "doc" is empty It turns out that in scripts/postprocess-unix.sh: THISDIR="`pwd`" LCDIR="${THISDIR}/librecad" RESOURCEDIR="${THISDIR}/unix/resources" TSDIR="${LCDIR}/ts" SPTDIR="${LCDIR}/support" DOCDIR="${SPTDIR}/doc" then later on: mkdir -p "${RESOURCEDIR}"/fonts mkdir -p "${RESOURCEDIR}"/patterns mkdir -p "${RESOURCEDIR}"/doc cp "${SPTDIR}"/patterns/*.dxf "${RESOURCEDIR}"/patterns cp "${SPTDIR}"/fonts/*.lff* "${RESOURCEDIR}"/fonts we probably need cp -a "${SPTDIR}"/docs/* "${RESOURCEDIR}"/doc because we're never copying the docs to unix/resources Is that right? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Scott,
I hope you didn't miss my previous mail si I will paste it again… ------------- Scott, make sure that this command can run fine: qcollectiongenerator LibreCADdoc.qhcp See line 10 and 11 of : postprocess-unix.sh It generates the helpfiles into a sqlite3 database file with the extension *.qhc and *.qch The OSX script copies them to the right directory using the following two lines cp librecad/support/doc/*.qhc $RESOURCEDIR/Resources/doc cp librecad/support/doc/*.qch $RESOURCEDIR/Resources/doc I think these two lines should be added to postprocess-unix.sh to create a complete package aswell... The background of the script are so that the user can compile and run LibreCAD without doing a full installation. ------------- Additionally, Qt's help system doesn't use the 'raw' HTML source, so you only need to copy two file to get the help working. The final package needs to depend on sqlite3 Ries On Apr 19, 2012, at 2:29 PM, showard314 [via LibreCAD] wrote: On Thu, Apr 19, 2012 at 3:19 PM, Scott Howard <<a href="x-msg://311/user/SendEmail.jtp?type=node&node=5652589&i=0" target="_top" rel="nofollow" link="external">[hidden email]> wrote: ... [show rest of quote] |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On Thu, Apr 19, 2012 at 3:42 PM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote: > Scott, > > I hope you didn't miss my previous mail si I will paste it again… I got it - i'm working on the merge now and testing |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On Thu, Apr 19, 2012 at 3:44 PM, Scott Howard <[hidden email]> wrote:
> On Thu, Apr 19, 2012 at 3:42 PM, R. van Twisk [via LibreCAD] > <[hidden email]> wrote: >> Scott, >> >> I hope you didn't miss my previous mail si I will paste it again… > > I got it - i'm working on the merge now and testing It's committed and working with the daily builds. Users should see it working within a few hours. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Apr 21, 2012; 6:29am.
I have just updated to LibreCAD SCM Revision 2.0 Alpha3.
When I select >Help -> Manual I get a blank display.
I have not yet been able to see the manual. Is there something I can do do fix this problem on my side?
Asking a question is not stupid, it is rather a sure way to get enlightened...
