Read ASCII Points Window are not showed
adrianoschunemann
I'm having a problem with the Read Points ascii plugin. On the first installation it worked normally, but after a few uses, the configuration window no longer appears. What can i do. I have it installed on Windows 10. Thank you.
Re: Read ASCII Points Window are not showed
Try to reinstall. Also try a newer build.
Also Options - Application Preferences - Defaults - Clear Settings - Layout or All may help.
