Read AutoCAD's DWG file format
Next Topic
6 messages Options Options
桃花潭水
Hello LibreCAD developers:
  I compiled LibreCAD according to the official documentation and can build it with QT, but I found that it seems to be not so friendly to AutoCAD DWG files. Even DXF files drawn in AutoCAD, I opened them with LibreCAD, and the text in the files was gone. What plugins can I use to improve these features?
        ——Xiao Ke
Re: Read AutoCAD's DWG file format
Dwg support is minimum. Dxf support is only up to dxf 2007.
        ——Xiao Ke
桃花潭水
Can I use LibreDWG, the open source DWG file library, to complete LibreCAD's DWG format
I think it's possible, if you want join the development.
Sadly it is still not possible for LibreCAD 2.*!
It was extensively discussed back in 2012 iirc that the LibreDWG license is not compatible with GPLv2, to which LibreCAD is still bound because of its QCAD roots.
Fabi94
1 post
If libredwg would be used as external library that is linked against, adding a linking exception for libredwg to the librecad copyright license terms should resolve that GPv2/GPLv3 issue https://www.gnu.org/licenses/gpl-faq.html#GPLIncompatibleLibs. There should already be such an exception there for Qt, since it is dual licensed under QT commercial license and GPLv3+ afaik, neither of which are compatible with GPLv2
