Read DXF support is not as expected
3 messages Options Options
Johnson
when I use LibreCAD to open a DXF format file, I found that the result is not as expected.
It seems the dxf format should be good because I use AutoCAD and DWGSee Pro to open it. It looks good.
is this the Librecad known issue or new bug found by me ?
Please use attachment to verify my finding.
 ABC.dxf
Re: Read DXF support is not as expected
Is an incompatibility
1. Unsupported entities, autocad screen capture:
The blue and red entities are unsupported ACAD_PROXY_ENTITY
2. Text "issues", autocad screen capture:
The unsupported chars in ACAD are "?" and opening it in my computer the fonts SimHei.shx, hztxt.shx, SimSun.shx are not found.
LibreCad screen capture:
The unsupported chars in LC are "diamond" and I copied two text and changed the font to wqy-unicode.lff
Re: Re: Read DXF support is not as expected
Johnson
Hi Rallaz
Thanks for your guide.
I saw in your capture that you could open this file by AutoCAD.  Please ignore the messy code such as ?
I suppose if you use LibreCAD,  you could not find this capture
this is the line but why LibreCAD did not support such entity.  while other DXF reader could support that ?
wingame82
Date: 2013-05-21 19:40
Subject: Re: Read DXF support is not as expected
http://forum.librecad.org/Read-DXF-support-is-not-as-expected-tp5708098p5708100.html
To unsubscribe from LibreCAD-user, click here.
