Relative line drawing in isometric grid.
cwr
cwr
I've tried drawing a line in polar coordinates from the relative zero point (which is locked).  Using the command line I _think_ the command should be eg: "@45<,10" for the first point in the line.  However, this just gives "Expression Syntax Error".  Does anyone know the correct input format, or can this not be done, or is it a bug?
Thanks - Will
Re: Relative line drawing in isometric grid.
Pascal
As we (I at least) don't have an online help for Librecad, I would suggest to use the QCad Manual.
Syntax for the polar point is DISTANCE<ANGLE
cantcode
cantcode
Pascam
In reply to this post by cwr
Try without the comma (the < takes place of the ,), so :
@45<10
Hope this helps
