Repeat Last Command
9 messages Options Options
Repeat Last Command
DaveEdwards
I've searched for this and didn't find an answer. Is there a simple way just to repeat the last command or icon selection?
TIA!
Re: Repeat Last Command
Last command:
Last command always is still active after operation, watch at the bottom at the mouse symbol, you are asked for the next step. If canceled with ESC or right mouse click, another right mouse click will offer the last commands in context menu.
Icon selection: No.
DaveEdwards
I can't find the last command on a right-click after and ESC or cancel. Maybe I'm just doing something wrong. Would entering a command whenever an icon was pressed make that command repeated as well - just a thought.
This post was updated on Jul 17, 2023; 11:16am.
When no command is active anymore a right click somewhere in the drawing area should give this:
A number of the last used commands are presented, click on the one you want.
Maybe I have misunderstood you. This feature does not work if the command was given by typing in the command line, only when induced by icon or menu.
DaveEdwards
Thanks - figured it out. That only works with commands selected via icon and NOT keyed in (which is the preferred method for productivity).
perepujal
Up arrow doesn't work?
Ha, I didn't know that! Probably was top secret. Now it's out.
perepujal
If you didn't know up arrow maybe you don't know [TAB]:
hit sp then [TAB] and you are presented with all the commands starting with sp     spline spline2
it also autocompletes the command with the first common letters.  spline
It works even if you don't write any letter, in that case it shows all available commands.
HTH
Pere
DaveEdwards
Thanks - I need to read the Users Guides more thoroughly.
