"Restore the Program to its original state" > "All", not working.
tiredbones
I would like to go back to the original setting. How is this done?
Some suggestions.
1. don't update the tree until everything works.
    Not very professional.
2. if you want to have the docking concept, then make
    sure everything can be dock, so that one can go back to
    to what there uses to. Such as the command line.
    I never saw a command to the right side of the screen.
   Sincerely,
   tiredbones
Re: "Restore the Program to its original state" > "All", not working.
"clear settings" → "all" deletes all settings.
"original state" is apparently an ambiguous way of saying: the new default settings.
The default layout will likely change again before the next stable release.
You can place the command line at the bottom if you want.
All toolbars / dockwidgets can be dragged and dropped.
https://youtu.be/-wnRZCFr2ds
