Retroceder: Re: Retroceder: Re: Circle - 2 points and radius
1 message Options
gabriel
Sorry the triangle thing dones not work
"jmweaver41 [via LibreCAD]" <[hidden email]> wrote:
Normally I use the perpendicular lines trick, and draw a circle tangent to those - my problem is that my circle isn't crossing at 90 degrees relative to the lines.  Basically its a triangle, I have the circle intersecting near a corner, so the center point is somewhere below and to the side.  I know the two points it will intersect the triangle at, and the radius of the arc between.
I think the command line version will work for me, I already know that I should be using it a lot more to simplify things, I just need to figure out the syntax and see if I can remember some of the math involved.
Thanks for the help, I'll try it out now!
http://forum.librecad.org/Retroceder-Re-Circle-2-points-and-radius-tp5709816p5709817.html
