Return to drawing from print preview
2 messages Options Options
David L Shumway
I do not find the way to return to the drawing after using print preview.  I have to reopen the drawing.  Is this the way it works?
Re: Return to drawing from print preview
Just use the Drawings menu or switch to Tab mode.
In Window mode, after closing the print preview, you presumably see the start-up unnamed drawing. But the drawing from print preview is still there.
In the Drawings menu you see a list of open drawings, which should contain the missed drawing.
In Tab mode it is more obvious, as each drawing has its named tab, which you can click to activate the drawing.
This behavior is indeed irritating and there is an open issue on GitHub, but sadly it is not solved yet.
