Rotate document by 90 degrees?
chollapete
Hi--
New to LibreCAD.  I'm looking to annotate some DXF drawings.  They are actually architects' drawings provided as PDFs.  I used CloudConvert.com to convert to DXF.  The file, a 54 MB floor plan of a 40-50,000 sq ft medical clinic loaded into LibreCAD nicely.  :)
The problem at hand is that the drawing loads in portrait orientation, so I would like to rotate it 90 degrees clockwise and save the change.
Is this a standard tool in LibreCAD?  I should note that I am using v, 2.1.2 on Debian stretch, which I realize is somewhat dated.  I'm working toward upgrading to buster, which is packaged with v. 2.1.3-1.2.  Or I can use daily builds if necessary.
Thanks for the time.
Re: Rotate document by 90 degrees?
Gary S
I'm on a newer version of LibreCAD, but try "Tools -> Modify -> Rotate".  The manual has a few more details.
chollapete
Thanks.  I was looking in View.
