Saving file does not save size?
tomb18
I have a gear that comes in as a DXF file.  If I look at the grid everything is fine in terms of the size of the gear.  If I then save the drawing and attempt to open it with MeshCam, there is no size information and it appears extremely small.
Can someone point me in the right direction?
Thanks
Re: Saving file does not save size?
Willem
I think it is a defect in the header of the dxf file. Try to save the file again to a new dxf file. Herefore you can use Teigha converter, This program is also useful to convert dwg to dxf, so I use it a lot. If this does not work you have to realise that dxf is a textfile and you can edit this with every editer ( leafpad or gedit) . On the Autodesk site you can find a pdf file that explains a lot of dxf files: http://images.autodesk.com/adsk/files/autocad_2012_pdf_dxf-reference_enu.pdf.
Hope this is useful
A lot of succes
