Scaling an imported image to fit a known length.
3 messages Options Options
Filip Wessman
1 post
I have been looking for this information but not found it here. If the question is already answered point me there and I will delete this post.
I am used to AutoCAD but am now moving to free versions. I was using FreeCAD for a while, but did not need the 3D-funtions so moved to LibreCAD.
In FreeCAD it was possible to import an image, and then scale it so that a known length got that actual length. I want to do this in LibreCAD to, but find no way to do it.
Say you have a paper map. You scan it, and then import it. There is a line on the bottom of the map with a scale. Thus you know that one specific line on the map is 10 meters. However if you draw a line along that line it will be 369.94256 mm. I want to reset the scale of the whole picuture so that the line is 10 000 mm when I am done.
There is a dead simple way to do this in FreeCAD. This tutorial show how to do it inf FreeCAD and will ilustrate what I want to do: (Timestamp 04:00)
https://www.youtube.com/watch?v=fJQvFsGXz-c&list=PLWuyJLVUNtc0UszswD0oD5q4VeWTrK7JC&index=4
How is the same thing done in LibreCAD?
Re: Scaling an imported image to fit a known length.
In reply to this post by Filip Wessman
For the scale option,
You can select a center, and a number or a pair of number to do anisotropic scaling.
