I'm probably missing something simple, but I'm stuck and would really appreciate some help with scaling an imported image...
I am trying using the procedure described at the link below but I don't see a resulting scaled image anywhere in my drawing.
http://forum.librecad.org/Scaling-imported-images-tp5711385p5711641.htmlTo be specific, I imported the image with its lower left corner at (0,0) which is also the reference point I select for scaling. In scaling options dialog, I set an isotropic scaling factor if 0.42 and I select "Delete Original" and have tried various combinations of "Use current attributes" and "Use current layer" but no matter what I do I don't see (or can't find) the resulting scaled image.
Thanks!
