Set grid divisions
4 messages Options Options
Set grid divisions
jerryemerydelacruz
Can the grid major lines be set to 1 inch with 16 inner divisions, representing a 1/16 of an inch.
Re: Set grid divisions
Unfortunately it seems it is not possible.
LibreCAD is of European origin and doesn't have much focus on imperial units, so some shortcomings in that respect.
jerryemerydelacruz
Seem absurd that such a fundamental property isn't available.  So much for librecad.
I have to correct myself.
After playing around a bit I have found some way. Set units to Architectural and precision to 1/16", grid spacing to 0.0625.
You can switch to Engineering after that, but the main grid will then consist of 10 1/16" units.
You may experiment yourself a bit with the settings.
If you are zoomed out too much so it's too dense for 16 sections to fit into one inch, less are shown. As soon a there is enough space it stays at 16 sections.
