Shortcuts
Shortcuts
kleinempfaenger
Hi, I was using the Qcad Community Edition for some time and I'm glad to find this project. Is there a list to view shortcuts in different languages, or is it always the same shortcuts?
Also, I would like to propose to make shortcuts editable, without the need to compile again and again. That was a, very effective, mechanism to make people buy the full Qcad version.
By the way, I cant find the help files, although documentation is installed.
I turned off the command line and cant find the way to switch it on.
Greetings, kl
Re: Shortcuts
probably be the same shortcuts but, undocumented.
You can add a "Feature Requests":
Start LibreCAD, then select menu Help->manual
Greetings, kl
right click on any toolbar, check "command line" or
"menu View->ToolBars->Command Line"
Re: Shortcuts
kleinempfaenger
Thanks for your reply.
I select Help - Manual, but nothing happens. Maybe it is also a problem of the official Ubuntu version, because help package is installed.
Re: Shortcuts
