I'm not sure if I fully got your problem, but here are some thoughts:
- you can draw a circle in the rotation center with a radius of wanted line length and use snap to intersection to draw or rotate the wanted line
- draw another circle in the ray center, with a wanted offset to the outer circle, passing the intersection point and use snap to intersection
- for multiple lines, construct one of them and then use rotation tool with multiple copies and keep original to multiply it
