Some (newbie) questions
7 messages Options
gevels
Hello, I'm new at this forum and a new (testing) user of Librecad.
As an architect I've been working with Minicad (later Vectorworks) for over 40 years.
Since I'm retired I only need a simple CAD program for a drawing every now and then.
My old VW license doesn't run on my (newer) iMac anymore so I'm testing Librecad at the moment.
A few questions:
- As the keyboard-shortcuts of VW are still "in my fingers" I wonder if there is way to edit / add shortcuts to menu items /commands in LC ?
- I read on this forum that the order of stacked objects on a layer can be altered by using Tools; Modify; Order, but that command is not in the list (see connected screendump) I'm using version 2.2.0.2.
Re: Some (newbie) questions
In different LibreCAD versions it might be found at different places.
gevels
Ok, Dellus, second problem solved (sort of); thanks for that.
What about my first question ?
In reply to this post by gevels
gevels wrote
A few questions:
Not really - https://forum.librecad.org/Customize-shortcut-hotkeys-td5718912.html
gevels
I took a look there, Firefly, but I don't think I will go that way.
But thanks anyway.
sand1024
you may also check the latest 2.2.2-alpha version (located there - https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.2_alpha-latest)
In that version, there are lots of improvements and one of such features is support of keyboard shortcuts, custom menus and toolbars.
