Special colors
Special colors
Dima
Special colors not work for object and layer.
I'm use current version of LibreCAD installed from ppa:librecad-dev/librecad-daily
Sytem xubuntu 14.04
Re: Special colors
Christian
In order to be able to use special colors you need to use either Properties or Attributes then select the entity and in Color select Others at the very bottom then click in Pick Screen Color, now you can select the color of your choice in the color selection square.
NOTE: you cannot change or select a special color for hatches.
Christian
Re: Special colors
Dima
I found the bug.
Special colours work when I'm use english language for GUI in preferences.
english GUI
When I'm switch GUI to russian language in preferences and I'm want use special colours for layer or objects I'm have do nothing  for dialogue select colours.
russian GUI
Re: Special colors
Thanks; I think I fixed it.
Re: Special colors
It looks like there is a similar problem with the snap indicator options.
These weren't intended to be translated.
