Straight line command
3 messages Options Options
accucutlaser
1 post
Any one pls provide me the shortcut for straight line command .which is similar to F8 in auto cad
Thanks
Thiru
Re: Straight line command
aman
It's hard to sit on two chairs at the same time.
Don't see LibreCAD as free AutoCAD(r). Read the docs, links are at the top of the front page if you want to learn LibreCAD.
At the bottom of the LibreCAD window are icons among others to restrict to horizontal, vertical or both, if those are what you are referring by 'straight line'
Or you can use the SHIFT key for the second point.
See https://forum.librecad.org/How-to-draw-straight-lines-in-free-snaping-tp5720318p5720356.html
