Stretch - selected, but unstretched lines vanish
Jim Winkler
This problem seems to have reappeared. I mentioned it on the closed bug report.
https://sourceforge.net/p/librecad/bugs/31/
Note: leading zeros shown for clarity of decimal.
Draw a rectangle 0,0 to 1,1
Draw a line 0,2 to 1,2
Select line
Tools/Modify/Stretch
Specify first corner: -0.5,0.5
Specify second corner: 1.5,1.5
Specify reference point: 0,0
Specify target point: 0,-0.5
Result:
Rectangle is stretched to 0,0 - 1,0.5
Line has vanished
Repeat - showing stretch including selected line does not vanish line
Select line
Specify second corner: 1.5,2.5 (note 2.5 to include selected line)
Result:
Line has moved to 0,1.5 - 1,1.5
Thanks! -Jim
Re: Stretch - selected, but unstretched lines vanish
I have tested it, you are right. But what's the point, the stretch command doesn't need anything selected previously, selection is done by pulling up the selection window when requested.
Jim Winkler
I find that things sometimes just vanish, sometimes large parts of my drawings, likely from being selected before stretching. This may happen when items are selected and not in the view. I might be focused on the stretch and don't notice other things being selected.  Sometimes things get selected outside of my selection box - a bug I presume. On occasion, I don't notice significant deletions for awhile and abandon all my changes by reloading the file. I often hit escape several times or check the selected items count to make sure everything is unselected before doing a stretch. I would find it quite desirable to fix this problem.
