Suggestion for "Divide into" tool
aangelo
Hi all!
LibreCAD has no way to easily divide (or simply mark) a line or circle into N segments.
The plugin "Divide" exists but it is not well integrated into the application and such command should be natively part of "Modify" menu.
Thank you in advance.
Antonio
Re: Suggestion for "Divide into" tool
toomed0011
Hi! 👋
You're right, LibreCAD currently lacks a user-friendly way to divide a line or circle into equal segments directly within the application. While the "Divide" plugin exists, better integration into the "Modify" menu would definitely enhance usability.
If you're exploring creative tools, you might also be interested in advanced editing apps. Check out WinkMody.com for resources and tools that could complement your projects!
sand1024
well, that actually depends on the version of LibreCAD.
Starting from 2.2.1 (it should be released soon), there is a "slice/divide" command that supports such division for lines and circle/arc.
In 2.2.2 (development alpha - there are even more tools and features to check
https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.2_alpha-latest).
aman
I have 2.2.0-alpaha, I had no difficutlies at all, draw a circle, select it, select Modify/Divide, select reference point, click to midpoint, and then how many slices you want.
