Text cut on high res' screen
raghouse
Win 10, resolution 3840 x 2160
Everything on the screen appears good except for a section at the centre at the bottom.
Re: Text cut on high res' screen
sand1024
which version of LibreCAD do you use? Production one or something from 2.2.1.. 2.2.2 tags?
Also, did you try to change either fonts or height of statusbar using Widget Options settings?
This is probably caused by OS font settings, see #1010
#1010 addressed two issues and it was probably closed with the fix of the other issue
