LibreCAD-dev
Search
everywhere
only in this topic
Advanced Search
Text cut on high res' screen
Previous Topic
Next Topic
Classic
List
Threaded
Locked
3 messages
raghouse
Reply
Threaded
Win 10, resolution 3840 x 2160
Everything on the screen appears good except for a section at the centre at the bottom.
sand1024
Reply
Threaded
Re: Text cut on high res' screen
which version of LibreCAD do you use? Production one or something from 2.2.1.. 2.2.2 tags?
Also, did you try to change either fonts or height of statusbar using Widget Options settings?
Reply
Threaded
This is probably caused by OS font settings, see
#1010
#1010 addressed two issues and it was probably closed with the fix of the other issue
investing less than half an hour into
Search
function can save hours or days of waiting for a solution
Free forum by Nabble
Edit this page
