Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hello Luca, On 2012-04-14 05:42, Luca Bellettati wrote: > > Hi! > I was working on librecas to add the support of single line text to the > application. I thought of creating a new class called RS_TextEntity in > engine package in order to put together the common things of mtext and > text, since many times in the project the differences between the two > are not taken into account, but only the fact an object is a text > entity. Am I right? In the meantime I create it and then I send it to > you and you give me feedback, if you agree with my idea, or just discar > it if I can do in another way. > On 2012-04-14 05:50, Luca Bellettati wrote: > > In the previous email I forget something. The class I want to create > will take the place of rs_textdata which now is duplicate, one for text > and one for mtext. Mine will put together what is common in the two, and > will add the specific features in the constructor of both rs_text and > rs_mtext class. > - I think it would be better keep the "rs_textdata" class, and make it (if not already done) the class holding common elements that will be used by "rs_text" and "rs_mtext" classes. My point is that "RS_TextEntity" looks like too much as being the class for the single line text entity, and thus is not a good class name to use for the common class. - So, if you agree with me, we will have the following classes structure: rs_textdata --\ |- rs_text \- rs_mtext Regards, Claude |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi Luca,
I agree that the current rs_textdata is good enough to hold data for both rs_text and rs_mtext. so, you may move rs_textdata definition to a separate header and be included for both. rename the current rs_text to rs_mtext, or make rs_mtext a derived class from the current rs_text. Also, need to make sure the rs_text and rs_mtext entities are saved/read properly by libdxfrw . LibreCAD saves all rs_text to AcDbMText in dxf currently. Feel free to choose the best design model based on your own work. Thanks, dxli |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I agree with Dongxu (dxli)
About saved/read by libdxfrw: MTEXT are read and translated to current rs_text TEXT are read and converted to current rs_text current rs_text are write as MTEXT if version are AC1015 (v2000) current rs_text are converted and write as TEXT if version are AC1009 (v12) That is read/write for TEXT and MTEXT are supported only require complete the rs_filterdxfrw |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by ClaudeQC
Hi!
I agree with you about the classes. Just two things: -woudn't be better if we use rs_stext for the single line (the new one) and rs_mtext for the old one? -in the structure you propose to me rs_mtext and rs_text are subclasses of rs_textdata? because I thought to create a rs_textdata.h file with the general rs_texdata class and then I created other classes in rs_text.h called rs_stextdata and in rs_mtext.h called rs_mtextdata. I upload the files just to be more clear. BR Luca rs_mtext.h rs_textdata.h rs_text.h |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On 2012-04-15 14:56, gnagno91 [via LibreCAD] wrote: > > I agree with you about the classes. Just two things: > -woudn't be better if we use rs_stext for the single line (the new one) > and rs_mtext for the old one? > - I am not aware of the implementation details of text entities in LibreCAD; but I know 2 things for sure. That 2 things is that in AutoCAD there is primarily too types of text entities: 1) Entities named "TEXT" (text formatted on a single line). 2) Entities named "MTEXT" (text formatted on multi-line). So, from my point of view, I think its a good idea to make LibreCAD class structure follow that name convention. i.e.: "rs_text" for "TEXT" entities, and "rs_mtext" for "MTEXT" entities. > > -in the structure you propose to me rs_mtext and rs_text are subclasses > of rs_textdata? because I thought to create a rs_textdata.h file with > the general rs_texdata class and then I created other classes in > rs_text.h called rs_stextdata and in rs_mtext.h called rs_mtextdata. I > upload the files just to be more clear. > - I think Rallaz, Dxli and Ries can help more than me in this area. Claude |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by gnagno91
Hi Luca,
please send in a pull request at github. I set up a branch for you to send requests: https://github.com/dxli/LibreCAD/tree/luca thanks, dxli |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Ok. I will send this afternoon since I have to modified something according to what Claude said to me!
Luca |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I had to change something and I will send a pull request in the next days.
Luca |
