The best way of copying, trimming and joining?
2 messages Options Options
ezequielleonzybert
This post was updated on Apr 20, 2024; 4:20pm.
I'm user of a laser cutting machine. After drawing the parts, I join and trim lines to make the machine path the shorter possible. So this is what I used to do on autoCAD to remove overlapping lines:
copy shapes, join them by snapping, trim the overlapped lines, make new single lines, join all the borders.
on LibreCAD I can't reproduce this workflow, so the best I could do was to explode all and then erase the overlapped lines. But depending on the polygons I'm working on , the explode of everything could be a mess to work with.
So my question is:
Is this the best way to do this on libreCAD?
thanks
EDIT:
Here you can see a real work comparison with these two methods to understand the difference:
Re: The best way of copying, trimming and joining?
There's no easy way to do it automatically.
We have libraries quite good at handling topologies, but not developed into this particular usage yet.
I know there are a few developers used LibreCAD for CNC, but features are added to LibreCAD.
Several ways,
You may develop a plugin on top of LibreCAD;
Or add new features to LibreCAD itself, like merging overlapped curves, and trimming to create closed contours.
